I am getting the error message below when I attempt to generate a report. Does anyone know what it means. I've included the DGN file as well.
1234567REQD.dgn
Hi Corey
I downloaded your dataset and get the same error message when trying to generate a horizontal report
It appears to be data specific to this particular complex, as I tried the same process on the other piece of geometry on this DGN and it worked OK.
I'll post the data to our internal development forum see if anyone has any ideas why this data is causing issue.
I also tried generating the reports from the ribbon and that didn't work either, although I didn't get the error message. This worked fine for the other piece of data too.
Simon Pegg
Bentley Civil Support
It does appear to be data specific and may be to do with this being a closed loop.
I played around with the geometry a bit and moved the point at the apex a bit and it then produced the geometry report.
I'll look at the data further, but I think its likely to be a defct.
Just curious if this was filed as a defect? Thanks.
