I have several corridors in different DGNs. Is it possible to run a batch process to process the different corridors? How would i go about doing this?
Also i have several different alignments/profiles. Is it possible to run a batch process to export alignments and profiles to native?
The first step toward setting up a batch process is finding the key-in commands that execute those steps.
You can research the Help file to find commands. You can also try to record a VBA macro. Sometimes that will give you the key-in strings that you need, sometimes it will give you bits of programming that (with a little work) can be cleaned up to be run through the batch process, and sometimes it gives you nothing useful...
If the process requires much user interaction, or if it requires conditions (like an If...Then) you may need to go to VBA for that kind of logic.
MaryB
