Dear All,
I am having problem in Creating 3d model, as you can see in the above image that there is a void/ gap in the corridor. Can any one help me to solve this error ?
Deval
Hello Deval,
Can you send across the dataset to check it here? Also, what is version number of ORD you have?
Hii Mam,
I am using ORD 2019 - Release 2 Update 7. And to check what are files you will required ? Shall i share only dgn (Or .itl template file and DTM also)
Can you share the .dgn file.
Attleboro Align 12122019.dgn
Mam, Please find the attached .dgn
Deval,
The gaps are created between 2 different end condition feature definitions (Type A4 and Type A7). The gap what you see is the TRANSITION between these two EC's.
See snapshots below from your dgn file. Try adding a key station at the middle of these gaps and it might fix!
Thank you,
Abhiram
