ROAD DESIGN (HERE ARE FILES ATTACHED).rar
i have attached those files i hope it will be of help for you friends to solve my problem.
Please help
which library are you talking about? can you provide captures? You are also running a very old product, have you considered upgrading to ORD?
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/33435/openroads-designer
its on the roadway designer then the template library during corridor creation after processing the corridor does not display..and all units are set to metric...
Have set the template to metric it only removed the message but the corridor does not appear..
Its true its the very old product but that's the only product that i have...does this mean there was no solution for this during the years of this old product..
i only i have Bentley InRoads Suite V8i (SELECTseries 2) 08.11.07.625
please help if there is
Hi, corridor works well regardless of the units. I am not sure why openning of ird is talking about imperial units. I created new ird file and everything is OK. Forget the old ird file and use this new. The files are attached. A few notes:* For creating of new surface from corridor go to Roadway Designer/Create Surface command. Then you can display lines and components in dgn. I recommend 3D dgn file.* Are you sure about lenghts in your template in your ird? When I look at original template in original itl (...\InRoadsGroup\data\metric\DefaultTemplates.itl), distances are shorter then in original. That seems you were translated it from metric to imperial. Or it is because something was wrong with units. Check it. In attached new ord file is used original template. * Our users have sometimes an issues with name "default" for name of project and horizontal alignment. Therefore, I recommend always creating a project with a different name from Default.
ird_alg.zip
Thanks this worked just fine and the corridor is working fine i now i have another situation..I'll start a new poster...expecting your help ...thank you again
