Hello All,
I wish to show the opening in the road side kerb at 10 m interval to drain off the surface water, how can I model it in Open road designer modelling? Also, How can I create a temple for this? Plz guide.
I am using 2019 Release 2 Update 7 version of ORD.
Thank you.
Aniruddha
I do not think it is possible to model holes every 10m in a kerb. Question - what or where would this hole lead to?
You could create custom linestyles for your kerb, one for the left side and one for the right. I would place the control point for the custom linestyle at the bottom face of the kerb. This will provide the visual appearance for the kerb. I'm not sure, though, that the mesh would reflect the holes/gaps. I don't think that the modeled kerb could be used for drainage analysis.
While it may not be exactly what you want but you could create a Curb Cut Typical section then drop it for 0.1m length to get the width of the hole you would use, you could drop this every 10m
Idaho Red
