Our Client wants us to run cross section reports for all of our stack files. When I try to run them, there are some that don’t print out in the .xsr file. The section is physically there in the stack file, but for some reason, it doesn’t read it in the .xsr file. Have you ran across this, and if so, do you have a solution for this?
Lawrence
Can you tell us what software you are running?
The file I am in right now is Power Geopak V8i SS4. These are 2D sections created with criteria. out of the 10 or so in the stack file, 2 are not showing up in the report.
