Def error, what is this error?
Hi Aaron,
Can you please elaborate as to when you are getting this error message, please send a brief of the workflow. What is the software & the version number? Does this happen on all the projects or this project in particular?
I am using ORD update 2 10.07.03.18. All I am doing is opening a dgn that has my named plan and profile sheet drawings. I have 5 dgn referenced in a dwg and a shp. It seems to be just when I open this dgn.
Seems to be I can't reference a .shp file
Getting same error on personal my mtcoles project which i have to done on asap basis! did you find solution for that?
Did you ever figure out how to upload a .shp file? I need to reference one into OpenRoads Connect.
