Does someone know if ORD can create annotation for stationing in the 3d model for an alignment and by which annotation group?
Thank You
Regards, Signe
Hi Signe,
I have just found in 2020 R1 that if you reference your 2D model of the Geometry into it's 3D model and annotate the Alignment (in the 3D model), all alignment annotation will be created with the correct 3D alignment elevations. This may work in earlier releases but i've never checked.
Probably not by design, but hopefully it keeps functioning this way in future releases as we've been using it a lot recently. The good thing is that it doesnt annotate based on the 3d alignment "chainages" but is still annotating the 2D Geometry and just using the elevations of the 3d.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Thank You - finally got around to test it and it worked for me as well.
