InRoads Create Cross Sections in SS10 V08.11.09.918
I need to create cross sections and there is not a command to do it.  Here is what I see:
  • No, but you do need an alignment and a terrain element, which can be from a reference file. The alignment has to be an Open Roads alignment which can be created from an ALG. if need be.
    If you only have a DTM, you can create a terrain element from it. The terrain element needs a feature definition, or an element template assigned to it. The level of the surface comes from the general level settings of the element template. If you are using a feature definition for the terrain element, it does point to an element template as well.
    Profiles are still plotted the InRoads way, using InRoads alignments and DTM's.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
