ORD Contour Line Scaling
Hello everyone.  I am learning to use ORD (specifically, OpenRoads Designer CONNECT Edition version 10.07.03.18), and I am experiencing an issue with scaling when referencing in a file.
I am attempting to reference in a file which includes contour lines.  When I reference it in, the contour labels DO NOT scale according to the drawing scale of the file into which it is referenced.  All other references scale correctly (including other annotation text in the file with the contour labels).  If I open the file with the contour labels in it and adjust the drawing scale there, the contour labels DO change according to the drawing scale.
The issue I am having appears to be the same as the issue experienced by this individual (to which no solution was provided):
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/167534/annotation-of-terrain-contour-text-when-referenced---ord
If anyone could help me with this, I would appreciate it!
  • Hi Joseph, The likely reason setting the drawing scale to 1=1 worked for you is due to the hard coded height/width in the TextStyles used within the Element Template's contour settings.  Unless the TextStyles were modified or hard coded to a specific size value and not a height/width scale factor (this depends on the client standards and Workspace)  the text should scale and adapt to the sheet/drawings they're referenced to, regardless of the scale of those sheets/drawings. For illustration, all images below are from Bentley's Training and Examples workspace.  The last image, I've included FDOT's guidelines for their text scale factors based on the target standard text size   (e.g. FDOT Small, FDOT Large, etc). - I believe most DOTs have done similar to follow Bentley's new Named Boundaries sheet scaling.  Some exceptions as always!  Hope this helps!
    ORD 2021 R1 (10.10), 2022 R1 (10.11.00.115), 2022 R3 (10.12.02.04) | MS 10.16
     Bentley Accredited Road Designer Bentley Accredited Road Modeler
      colliersengineering.com
