The elements in the drawing model coming from annotation group (profile frame and table) do not conform to the specs defined in the library. Lines weight and style are set to 0 while in the style library they are defined differently. The case is only apparent when the profile drawings are created outside of the geometry file i.e. in new file created from defined named boundaries.
Is it a feature or bug?
Hi Benedykt
I think I have replicated this issue. I think it is a defect. I will see if there is any workaround.
Simon Pegg
Bentley Civil Support
The other geometry file which I produced profile drawings from and sheet models, also in separate file, gave proper results. It must be intermittent and somehow related to the geometry file itself or seed file from which the drawing and sheet model is created.
BTW is it normal that creation and annotation of 30 drawings and sheet models take one hour to complete and 30 GB of ram? Granted the alignment is 60km long but still the performance is so poor
