Good Morning,
As a result of some file restoration, it appears that my Superelevation Section has lost its association with the horizontal geometry from which it was created. This appears to be preventing it from applying to the corridor properly. Is there a tool similar to the "Reattach Corridor" Tool to restore the Superelevation Section association from its horizontal alignment?
Thanks in advance as always!
Hi Robert, I'm not aware of such a capability with ORD, do you want to file an enhancement request?
That would be great! Its not the end of the world to have to recreate the superelevation section, especially we use CSVs generated from Excel spreadsheets that went through our QC process, but such a tool would definitely save time in this scenario, and shouldn't be hard to implement since Reattach Corridor pretty much functions the exact same way.
I filed the Enhancement 1074730:reattach superelevation to a different alignment
Answer Verified By: Robert Huston
Does the superelevation have association with any horizontal alignment? If so, and you want to swap that to a new alignment the key in "geometry element replace" will do this....among other things. So user beware. This key in will replace all referencing geometry from one element to another.
I will definitely take a look at this. Thanks for the heads up!
