Good Morning,
As a result of some file restoration, it appears that my Superelevation Section has lost its association with the horizontal geometry from which it was created. This appears to be preventing it from applying to the corridor properly. Is there a tool similar to the "Reattach Corridor" Tool to restore the Superelevation Section association from its horizontal alignment?
Thanks in advance as always!
Thanks Marc! I will update my tracker.
It would be nice to have a support tool that would allow the reassignment/reattachment/reruled of any smart element from one smart element to a different smart element. So that a smart element that is a referenced as a rule, that may have been corrupt or otherwise made unusable but is still selectable, can be replaced globally with in a DGN with a different smart element.
I tried this and the response was that the superelevation section was not valid for the tool. Good to keep in mind though. Thanks again for the feedback!
Robert,
When using this tool you do not pick the superelevation object, you pick the old centerline and then replace it with the new.
