Right at the end of installing the OpenRoads SignCAD program the installation is rolling back and giving an installShield error that "The Wizard was interrupted before OpenRoads SignCAD could be completely installed. Your System has not been modified. To Complete installation at another time, please run the setup again."
An icon temporarily appears for SignCAD, but then is removed.
Using the orsc10000012en.msi file on Windows 10
Hi Richard,
I had this resolved via a Service Request. It seems to be an issue with Connection Client. I had to uninstall Connection Client, Install SignCAD and then re-install Connection Client.
Hopefully fixed soon, but this workaround worked for me.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Hi Mark,
That was the solution that Bentley sent me, but I still get the same result with SignCAD. I am using the 10.00.18.13 version of Connection Client.
That was the version I used as well. Did you restart after uninstalling CC?
Uninstalling CC and restarting worked for me.
