Has any came across the problem with annotating superelevation diagram? I've got a simple alignment with superelevation section which I created for the purpose of creating annotation group and I found diagram isn't showing correctly. Attached is screenshot showing superelevation view (on the top) with correct diagram and annotated profile with wrong diagram (on the bottom). Is it a bug? Regards, Krzysztof
Can someone provide me a dataset I can test with the next version?
You can use this link to upload your files: https://bentley.sharefile.com/r-r9ec9de04bf44817b
Wouldn't it be sensible to create one on your own using seed from the latest version?
I copy what I told you by email to share with other users:
If I try with a dgn file created with a previous version of ORD, I get the same issue but with a brand new file the result seems better, see screenshots below, still it doesn’t place all the labels at the right place but it seems to draw a more reliable diagram.
So an update/upgrade issue of superelevation created in a previous release?
Mark
Hi Marc,
FYI, I just annotated the profile in the latest ORD and still getting the same problem with superelevation diagram.... Could you please investigate?
Sorry, update, I don't get the diagram at all - brand new file, new alignment and new superelevation...
Mark,The design file which stores SE definition was created a few ORD releases ago, are you saying we're suppose to recreate it from scratch? I'm running 2020R2 and still having this problem. Can this be addressed? Unless Bentley can provide resources to recreate the model from scratch.
Regards,Krzysztof
