Has any came across the problem with annotating superelevation diagram? I've got a simple alignment with superelevation section which I created for the purpose of creating annotation group and I found diagram isn't showing correctly. Attached is screenshot showing superelevation view (on the top) with correct diagram and annotated profile with wrong diagram (on the bottom). Is it a bug? Regards, Krzysztof
I am not from Bentley, but still took a look. Looks sth is wrong with super-elevation diagrams on profiles. I have similar results to yours.
Hopefully 2019 R3 is postponed as they are making product usable finally ;)
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
Can someone provide me a dataset I can test with the next version?
You can use this link to upload your files: https://bentley.sharefile.com/r-r9ec9de04bf44817b
Wouldn't it be sensible to create one on your own using seed from the latest version?
If I can test with an example that I'm sure didn't work with 2019R2 we eliminate any other factors.
I will email it to you.
