PowerSurvey importing survey data type variable
under the survey data import, the file type only shows .txt files where the the other import types go. I believe it is a variable that was replaced as I opened up inroads survey and the other types were visibile the first time and then when I went to load another file all of the types disappeared with the exception of .txt????
