Hi, i'm Wildan. Civil engineering student from indonesia
I've made a bridge modeling using openbridge. I've made the pavement marking using stencil tool. But now the pavement marking can not be remove. I've detached pavement marking attachment, but the stenciled one is still there. Can someone help me to erase the pavement markings, please?
Hi Wildan,
The way to remove a stenciled marking depends on the method how you placed it. Have you tried to simply delete the elements with the Delete tool? If so, can you check if the marking is attached as a reference. I understand you detached the reference in the Reference Manager. Can you check if you done that with the right View activated.
If you use multiple views with multiple (2D, 3D, profile, etc) models, it is important to check which view is active when detach a reference.
Louis
Have you tried deleting the 'Stencing model' which is referenced into your bridge model?
Answer Verified By: wildan hero
Not yet. Thanks a lot. It can be removed that way
Deleting the model is an extreme method - you could (as Louis says) just detach (or turn off the display of) the referenced model. This would be a better method if you needed to see the stencil later.
