Hi.
In ORD, when I import a 1m cube from a SAT file, the sides are imported as 0.3849 m when I set the import units to mm. The file is exported from AD Inventor, and the import is working as expected in PowerCivil.
The file is attached to this post for testing.
Is this a known issue, or could this be related to my specific workspace? My seed file is set to metric with meters as master unit.
1m_cube.zip
Hi Thomas,
This was not a known issue; however, I have tested your .SAT file and was able to duplicate the behavior you experience, thanks for uploading.
I have filed Defect 1074816 - ACIS SAT import units are not correct with our Development group and included you information.
Sanders
Answer Verified By: Thomas Stavik-Karlsen
Great, thanks.
Thomas H. Stavik-KarlsenSenior Engineerhttp://www.Akersolutions.com
