I have LIDAR that has 50+ classifications. Is there any way to have ORD recognize all of the classifications? or at least a way to select which classifications are associated with the standard POD classifications?
This may help - you can create your own classification with the following. If the definitions are stored in a DGNLIB, they would then be available to all users.
From the Reality Modeling workflow, open the Point Clouds dialog > Settings/Reality Model Presentation > Class Definitions > Define Class.
