ORD Dynamic Label location and symbology
Is there a way to stop the location and symbology of dynamic labels from resetting every time an element is moved? I want the label to be dynamic, but not the level and location. I can think of a lot of scenarios where a designer would want the change the default level and location of a label. I've attached a short video for clarification.
  • Luke:
    You will need to create an annotation group which will direct the annotations to the symbology you desire. Initially, I made a copy of the Bentley default annotation group and then set up levels in element templates to direct the symbology. The process becomes quite easy if you export a group to XML and do a universal search and replace in notepad to replace the Bentley levels with your own. Then you can import that XML into your features*.dgnlib. We have 85 alignment styles in our office and this is how I did ours. You can do the same thing with the profile annotation groups, of course. Bentley has everything already set up and their annotations work well, even though I changed a LOT of their styles to meet the requirements of our client. Get familiar with importing/ exporting XML if you are not that familiar with the process. It is IMPOSSIBLE to expeditiously create annotation groups without it.
    Mark
    Mark Anthony Plum
    Chief Technology Officer
    1601 N.W. Expressway, Suite 400
    Oklahoma City, OK  73118
