Top Surface/TIN issue
Has anyone else had this issue before? My corridor behaves like it is supposed to in this super elevated transition area but the yellow line on the right side is the top surface that Openroads generates. Also when I export to a TIN file it is doing the same thing, ignoring the gutter line thru this area.
When I export a TIN file for our subs this will give them incorrect elevations.
Thank you
Parents Reply Children
