Just downloaded 10080088e.exe It keeps failing when I try and do a default install. The error says "Failed to copy payload for Bentley DgnDb iModel Importer 1.6 x64. I have gotten other errors but they all essential refer to the inability to download a payload file. I filed a ticket but they often take a few days so I thought I would try here. We are 90% ready to deploy but I wanted to test with this new release. So not being able to download is not a good thing.
I don't know about that particular error. You could try to download the full install first. Run the installer from a command line with the "/layout" switch.
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022
Hi Steve,
Have a look at this - https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/40402/failed-to-copy-payload-for-bentley-dgndb-imodel-importer-1-6x64
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
That's how I got the error. I deleted all the files in C:\ProgramData\Program Cache and deleted the old install package for the 2019 R3 version that was live for a few days and now it is downloading. Thanks for your help.
I deleted all the file in the Program Cache folder and then found an old install for the 2019 R3 that I had downloaded. I deleted that and it is installing now. Thanks for your help.
