Hi all,
Does anyone know how to enable (if possible) Task Navigation in ORD 2020 R1 like in Microstation CE Update 13?
I'm not expecting any of the Civil tools to be available there, but hoping to use the CAD Tasks interface
Mark
Try MS_TASKNAVIGATION_CONFIGURATION and add New Value 1 (in Configuration Variables)
That config variable was only needed up to MicroStation Update 12 - see the following.
https://communities.bentley.com/products/microstation/w/microstation__wiki/43148/enable-v8i-task-theme-in-microstation-connect-edition
Same here, hence the question. Not sure why it would be disabled in ORD?
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Unless it's due to this:
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/191426/ord-enabling-task-navigation-still-breaks-workflows---2019-r2-update-7-10-07-03-18
and
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/142526/ord-missing-openroads-workflows-on-qat/432293#432293
