since new update of ORD I encountered plenty of problems when using display rules or adding templates to corridor with new components. Every time I get an error with message Exception logged to:...
It only happens when I try to add something new to corridor like template with new components or turn on display rule which displays new component. What is strange that such templates work correctly in new files but not in created in U7 and before.
Does anyone know what could be the problem? I uploaded last free exceptions that I had received.
Best regards
Krzysztof Jędrych
Exception caught in source file e:\Builds\cif10080088\Source\Cif\src\managed\ui\tools\PrimitiveCommand\PrimitiveCommand.cs at method OnDataButtonInternal ================================================================================ Exception : The ObjectSpace was previously disposed In Assembly : Bentley.CifNET.Objects.4.0 Stack Trace : w Bentley.CifNET.Objects.Engine.ObjectSpace.CheckDisposed() w Bentley.CifNET.Objects.Engine.ObjectSpace.GetInstanceInternal(ObjectKeyInternal key, Boolean mustBePersisted) w Bentley.CifNET.Objects.Engine.ObjectSpace.GetObjectInternal(ObjectKey ecKey, Boolean persisting) w Bentley.CifNET.Objects.Engine.ObjectBucket.GetObject() w Bentley.CifNET.Objects.Engine.ObjectHolderInternal.get_ObjectReference() w Bentley.CifNET.Model.NamedEntity.GetNamedEntitySet() w Bentley.CifNET.Model.NamedEntity.GetIsNamed() w Bentley.CifNET.Model.EC.ECNamedEntityBinder.SnapShot.IsNamingRefenceSolved(NamedEntity ent) w Bentley.CifNET.Model.EC.ECNamedEntityBinder.SnapShot..ctor(NamedEntity ent) w Bentley.CifNET.GeometryModel.EC.ECLinearEntity3dBinder.SnapShot..ctor(LinearEntity3d ent) w Bentley.CifNET.GeometryModel.EC.ECLinearEntity3dBinder.GetSnapShot(Object obj) w Bentley.CifNET.Objects.Engine.Instance.StoreSnapShot(Boolean haveToRecreateSnapShot) w Bentley.CifNET.Objects.Engine.Instance.BuildChangeSet(InternalChangeSet changeSet, PersistDepth persistDepth) w Bentley.CifNET.Objects.Engine.ObjectSpace.ReleaseChangeSetBuild() w Bentley.CifNET.Objects.Engine.ObjectSpace.ApplyBusinessRules(ICollection`1 chgs) w Bentley.CifNET.Objects.Engine.ObjectSpace.ProcessChangeSetInMemory(InternalChangeSet changeSet, InstanceChangeEventAggregation externalEventArgs) w Bentley.CifNET.Objects.Engine.ObjectSpace.ProcessChangeSet(InternalChangeSet changeSet, InstanceChangeEventAggregation externalEventArgs) w Bentley.CifNET.Objects.Engine.ObjectSpace.HandlePersistenceModeTransition(PersistenceModeTransition transition) w Bentley.CifNET.Objects.Engine.ObjectSpace.PersistTransients() w Bentley.CifNET.Objects.Engine.ObjectSpace.Bentley.CifNET.Objects.IObjectSpace.PersistTransients() w Bentley.CifNET.GeometryModel.Tool.GeometryCommand.ObjectSpaceHolder.PersistTransients() w Bentley.Civil.RoadwayDesigner.Commands.CreateParametricConstraint.MoveToNextState(CreateParametricConstraint command) w Bentley.CifNET.UI.Tools.ParameterEntryState`2.Entered() w Bentley.CifNET.UI.Tools.ParameterEntryState`2.InternalPrimitiveParameterState.OnParameterAccepted(AcceptMethod acceptMethod, Object parameterValue) w Bentley.CifNET.UI.Tools.ParameterState.DoParameterAccepted(AcceptMethod acceptMethod, Object parameterValue) w Bentley.CifNET.UI.Tools.CursorPrompt.ParameterPromptManager.PromptDialogManagerOnDialogResult(Object sender, DialogResultEventArgs e) w Bentley.CifNET.UI.Tools.CursorPrompt.PromptDialogManager.SetResult(Object value, AcceptMethod acceptMethod) w Bentley.CifNET.UI.Tools.CursorPrompt.ParameterPromptManager.Bentley.CifNET.UI.Tools.ICommandParameterPrompter.OnDataPoint(IButtonEvent pointEvent) w Bentley.CifNET.UI.Tools.PrimitiveCommand.<>c__DisplayClass106_0.<OnDataButtonInternal>b__0() w Bentley.CifNET.UI.Tools.PrimitiveCommand.ManagedBooleanCallBack(Func`1 method, Boolean exitCommandAndCleanupCaches, Boolean retValue, String message, String memberName, String sourceFilePath, Int32 sourceLineNumber)
Exception caught in source file e:\Builds\cif10080088\Source\Cif\src\managed\ui\tools\PrimitiveCommand\PrimitiveCommand.cs at method OnDataButtonInternal ================================================================================ Inner Exception : Odwołanie do obiektu nie zostało ustawione na wystąpienie obiektu. In Assembly : Bentley.ECObjects.MixedMode3 Stack Trace : w Bentley.ECObjects.Instance.ECDInstance.InitClassLayout(IECClass ecClass) w Bentley.ECObjects.Instance.ECDInstance..ctor(IECClass ecClass, ClassLayout classLayout) w Bentley.ECObjects.Instance.StandaloneECDInstance..ctor(IECClass ecClass) w Bentley.DgnPlatformNET.DgnEC.DgnECManager.CreateECDInstanceFromNativeInstance(IECInstance* nativeInstance, DgnFile dgnFile) w Bentley.DgnPlatformNET.ItemType.CreateTemplateInstance() w Bentley.CifNET.GeometryModel.RoadwayDesigner.Corridor.LinearEntity3dEvaluationBucket.Commit(Corridor corridor, String name, IObjectTracker objectSpace) w Bentley.CifNET.GeometryModel.RoadwayDesigner.Corridor.EndEvaluation(IObjectTracker objectSpace) w Bentley.CifNET.GeometryModel.RoadwayDesigner.BaseCorridorRule.Evaluate(IObjectTracker objectSpace, IEnumerable`1 changeEvents) w Bentley.CifNET.GeometryModel.RoadwayDesigner.BaseCorridorRule.Evaluate(IObjectTracker objectSpace, IEnumerable`1 changeEvents, DependencyCycleInfo info) w Bentley.CifNET.Objects.RuleManagement.ActionList.ActionNodeRoot.Process(IRuleEvaluationLogger logger, DependencyCycleInfo transactionInfo, CheckStopProcessingRule checkStop, Int32 waveCount) ================================================================================ Exception : Error in Rule Evaluation In Assembly : Bentley.CifNET.Objects.RuleManagement.4.0 Stack Trace : w Bentley.CifNET.Objects.RuleManagement.ActionList.ActionNodeRoot.Process(IRuleEvaluationLogger logger, DependencyCycleInfo transactionInfo, CheckStopProcessingRule checkStop, Int32 waveCount) w Bentley.CifNET.Objects.RuleManagement.ActionList.ProcessEvaluableCandidates(IRuleEvaluationLogger logger, DependencyCycleInfo info, CheckStopProcessingRule checkStop, Int32 waveCount) w Bentley.CifNET.Objects.RuleManagement.ActionList.ProcessChanges(IEnumerable`1 changes, IRuleEvaluationLogger logger, DependencyCycleInfo info, CheckStopProcessingRule checkStop, Int32 waveCount, RuleEvaluatorFilter ruleFilter) w Bentley.CifNET.Objects.RuleManagement.ActionList.ProcessWave(IEnumerable`1 changes, IRuleEvaluationLogger logger, DependencyCycleInfo info, CheckStopProcessingRule checkStop, Int32 waveCount, RuleEvaluatorFilter ruleFilter) w Bentley.CifNET.Objects.RuleManagement.RuleManager.ProcessWave(IObjectTracker objectSpace, IEnumerable`1 changes, CheckStopProcessingRule checkStop) w Bentley.CifNET.Objects.Engine.ObjectSpace.ApplyBusinessRules(ICollection`1 chgs) w Bentley.CifNET.Objects.Engine.ObjectSpace.ProcessChangeSetInMemory(InternalChangeSet changeSet, InstanceChangeEventAggregation externalEventArgs) w Bentley.CifNET.Objects.Engine.ObjectSpace.ProcessChangeSet(InternalChangeSet changeSet, InstanceChangeEventAggregation externalEventArgs) w Bentley.CifNET.Objects.Engine.ObjectSpace.HandlePersistenceModeTransition(PersistenceModeTransition transition) w Bentley.CifNET.Objects.Engine.ObjectSpace.PersistTransients() w Bentley.CifNET.Objects.Engine.ObjectSpace.Bentley.CifNET.Objects.IObjectSpace.PersistTransients() w Bentley.CifNET.GeometryModel.Tool.GeometryCommand.ObjectSpaceHolder.PersistTransients() w Bentley.Civil.RoadwayDesigner.Commands.CreateParametricConstraint.MoveToNextState(CreateParametricConstraint command) w Bentley.CifNET.UI.Tools.ParameterEntryState`2.Entered() w Bentley.CifNET.UI.Tools.ParameterEntryState`2.InternalPrimitiveParameterState.OnParameterAccepted(AcceptMethod acceptMethod, Object parameterValue) w Bentley.CifNET.UI.Tools.ParameterState.DoParameterAccepted(AcceptMethod acceptMethod, Object parameterValue) w Bentley.CifNET.UI.Tools.CursorPrompt.ParameterPromptManager.PromptDialogManagerOnDialogResult(Object sender, DialogResultEventArgs e) w Bentley.CifNET.UI.Tools.CursorPrompt.PromptDialogManager.SetResult(Object value, AcceptMethod acceptMethod) w Bentley.CifNET.UI.Tools.CursorPrompt.ParameterPromptManager.Bentley.CifNET.UI.Tools.ICommandParameterPrompter.OnDataPoint(IButtonEvent pointEvent) w Bentley.CifNET.UI.Tools.PrimitiveCommand.<>c__DisplayClass106_0.<OnDataButtonInternal>b__0() w Bentley.CifNET.UI.Tools.PrimitiveCommand.ManagedBooleanCallBack(Func`1 method, Boolean exitCommandAndCleanupCaches, Boolean retValue, String message, String memberName, String sourceFilePath, Int32 sourceLineNumber)
While I can't say for certain, I suspect there is some backwards incompatibility in the new update.
MaryB
I'm curious, are the new files, the ones that work, created with new (2020R1) seed files? This could be an important piece of knowledge as we develop our ORD environment.
Nope, the new files that work are created with old seed files, which were not touched since U6 if I recall correctly.
Thankfully upgrade from 2019 Release 2 seems ok...
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Thanks. Good to Know.
