Having problems with customized tabs not showing in ORD.
Symptoms are the tabs from customized dgnlibs do not show up unless they are in their own workflow.
If customized tabs are placed within the Drawing workflow for example, they do not appear in the ribbon. The file is read as expected and it shows up in the variable list fine.
If i create a workflow and place the tab into that workflow, it shows up as expected when that workflow is selected.
Is this by design or is this a bug?
We have been able to have the tabs in the Drawing workflow up to this point. Is this a new direction for the ribbon? It seems that we will not be able to intermingle any customizations within the delivered products"space".
Robert
This has been filed as a defect
Defect 1076370:[OpenRoads Designer] Custom Menu ceased to show up in new release
Thanks for the response! Hopefully this will be bumped up enough to make it in the next release.
Thank you, Nico Roman. We too have seen this bug and would like it fixed. I opened SR # 7001035444 for it just now and mentioned the Defect # in my SR.
Is this the reason AutoTURN tab/menu is gone?
Yes, it is the reason the tab is missing. You can edit the autoturn dgnlib to move the ribbon items to its own workflow till a fix is made available.
