Having problems with customized tabs not showing in ORD.
Symptoms are the tabs from customized dgnlibs do not show up unless they are in their own workflow.
If customized tabs are placed within the Drawing workflow for example, they do not appear in the ribbon. The file is read as expected and it shows up in the variable list fine.
If i create a workflow and place the tab into that workflow, it shows up as expected when that workflow is selected.
Is this by design or is this a bug?
We have been able to have the tabs in the Drawing workflow up to this point. Is this a new direction for the ribbon? It seems that we will not be able to intermingle any customizations within the delivered products"space".
Robert
Thanks for the info. Not very customization savvy so I don't how to move ribbon items to a workflow.
