Has anyone been able to get their third-party tabs to show up with the OpenRoads Designer CONNECT Edition - 2020 R1 Update 8 (v10.08.00.88) release that just came out? I'm unable to get Cadig's AutoTable or Transoft's AutoTurn to show up, despite having the configs looking in the correct places. I can load them via the MDLs and use them via their key-ins, but I can't get them to show up in the Drawings workflow the way they did prior to my recent update. I've also uninstalled AutoTURN and reinstalled it, but no luck on the ribbon integration. Thanks in advance.
This may be related to another thread:
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/191938/ord-2020-r1-missing-customized-tabs-problem-or-by-design
Apparently there is a defect in this newest release (fancy that).
MaryB
Hi Dan,
Have a look in the Drawing Workflow as this is where the Microstation ribbon tabs go. We use the Customize Ribbon command to add them to a custom ribbon dgnlib to be shown in the ORD ribbon workflow.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Regarding that defect, I'm not seeing it in our workspace for 2020 R1?
Thanks MaryB - sure looks like the same thing. I appreciate it! I searched the forums before posting this question, but I guess I missed it. If this is the biggest defect in this release - I'll take it! Besides, they have a long way to go to replicate the debacle of last summer's version. Cost us a lot of money... Have a good one.
Thanks Mark - I think MaryB's link above is what I'm seeing. I was in the Drawing workflow and tried a number of things per Transoft's support recommendations and still nothing. If you're using AutoTURN Pro and you're seeing the tab, please let me know. I'll pass that on to Transoft's support, as last evening they responded that they researched it as well. They said that it appears that something in the latest release's workspace is causing the ribbon not to load. They did, however, suggest opening the toolbox - which I hadn't thought of. It worked for AutoTurn and Torus but not AutoTable, so I'm still looking at the key-ins for that one. Thanks again, I appreciate your input. Have a great day!
