ORD disappearing 2D lines
Sometimes lines in my 2D model will disappear entirely, while they are still visible in the 3D model. In the attached file, this happened with some of the bicycle path lines (level N-WE-VH-KANTVERHARDING_FIETSPAD-G), but not with all of them. This happens in other models with other lines as well, although ususally not with that many lines at the same time. Some colleagues have reported the same problem.
I have opened this file on different machines, one with 2018 R4 and one with 2020 R1 and it happens with both. Any idea what could cause this behaviour and how I could fix it? I have tried processing, reattaching en rebuilding the corridor, but neither helps.
Thanks in advance!
Kind regards,
MerlijnChurchillweg variant +1M aansluiting.dgn
  • Hi Merlijn,
    You're file is interesting. When looking to it I saw some peculiarities. Did I see it right that there are some steering lines in the Default-3D model (see image below)?
    If it is possible, I should prevent this. Steering lines works best if they are in the 2D model.
    This might also be the source of the problem. If two lines are above each other in a corridor, ORD only shows the most upper one.
    When I draw a steering / control line in the 2D model and attach a Corridor to it, then the edge of the bicycle lane is also visible in the 2D model.
    Regards Louis
