End Area Volume - Classifications
I am running InRoads SS4.  I am trying to calculate cut but only in a certain part of the road. I have changed my template so I can ignore the components I need to in order to get that certain section.  My issue is the following:  there is a column in the classifications that shows what the component is a part of (this is typically a certain corridor). Before I changed the template in the corridor it had said Corridor 20-60 that was needed.  Now after changing the template and updating the corridor it is saying Sta. 22+60.  The new template was applied throughout the entire corridor, not just at a certain station.  Is there a way I can get it to be the entire corridor again?
