Can anybody tell me how to get this to display, the Bentley training session webinars are referring to it constantly and mine does not seem to appear.
Thanks in advance,
Mike McWilliams
Mike, Just go to the Home tab and in the Primary category you should see the Explorer. Just click on that and then you can dock it on the left (if it doesn't already dock itself once you select the tool)
Thanks for the reply, Joe. but when I dock it, the <properties> tab is still missing. (see attached)
Mike, Just click the pin (the middle button) on the explorer dialog. That will collapse the Explorer (but still remain docked) and then the Properties dialog should be revealed.
It works!. Many thanks, Joe!
Answer Verified By: Michael McWilliams
