ORD has anyone else had problem with the popup/quick access element info/properties not holding the changes to a feature like line, text... For example, i select a line or text and click on the quick access popup, properties, and change the selected feature to a different level and it just goes back to what it was before i changed it.
Hi Aaron,
There is a defect in for this. It doesn't work for CAD symbology at all although looking like it's doing something. Hopefully this is fixed in the next ORD version...
Mark
