I was using Civil Accudraw tool while doing my vertical design in ORD 2019 R1.I'm facing two problems
1. Previously there was one tool "dz" which provides the elevation difference from last point. This is currently not appearing.
2. Previously it was appearing, but the "dz" and "slope" value were not current, as it is calculating the "dz" and "slope" value with reference to (0,0) point.
Can anyone kindly tell me what I'm missing here and any fix to this problem?
Thanks in advance.
Snehasish Mondal.
1. I believe all you need to do is hover over a button in the Civil Accudraw box and hold down your secondary button on your mouse. A small menu should pop up where you can toggle what is in the box, and it should look like the one below.
2. Try checking your Civil Accudraw Settings, and make sure the Floating Origin box is checked. This should move the origin with your mouse clicks. You should also be able to use the "O" key while Civil Accudraw is on to move the origin wherever you like.
Jacob
Answer Verified By: snehasish mondal
Thank you Jacob for your quick reply. The first problem is resolved as you suggested. But, after checking the Floating origin box, the origin does not move with mouse click. A precised elevation difference to a point can be provided by pressing "O" and selecting a reference point.
So, it answers my question. Thanks a lot.
