We are experiencing dgn files loading slowly with ORD in Projectwise. We have gone as far as commenting out all varies except the absolute necessary ones. (dgnlib, cellist, civil content, seed files, etc...) Still is slow loading between opening files.
We started using Bentley's default workspace as a template but it is so full of open variables and directives it is hard to see what is slowing it down.
Just wondering if anyone has got ORD to run fast as v8i on Projectwise.
Good to know that there was a reason behind the speed boost in .262.
We will be taking a look at this. I was not aware of this video to date. Thanks for bringing it to my attention.
For us, its a pretty standard one-third initial startup, one-third reference scanning, and then one-third "the file has opened but you can't do anything in it yet". Honestly haven't had any issues with the MWS dialog.
Both. Right Now after defining folders with variables to download before being called out, ORD is running quite well. It is taking 20-30 seconds between files. Which is fast as you are probably going to get with the check-in dialog. Also the software seemed laggy before, looking for resources when doing certain commands.
I would definitely recommend looking into this, if you want to speed Projectwise up in ORD.
