ORD Road profiles and 3D Cuts
Question about profiles and 3D Cuts.  We have a road profile that when displaying 3D Cuts we get a weird cell showing up along the profile.  Where is the ORD setting that controls the cell or object that is displayed in 3D Cuts?
Thanks in advance
  • Hi Chris,
    The 3D model is referenced to the profile model so you may use level display manager to control the levels displayed in the profile view
    Vincent RAULT [Bentley]
  • I believe there is a bug in the 10.7 version that does not honor level display.  You could try global display instead.
    I think that setting is in the feature symbology.  Check the 3d settings.  There is an element template that is assigned there.  Either remove this template of edit the element template to remove the cell display.
  • Alternatively, you may use display rules to control what is displayed or not in the cut volume.
    I recorded a video to illustrate workflow
Reply
