Using Item Types with Linear Templates
I want to be able to apply an Item Type that describes some non-graphical properties of a linear item (eg a kerb) to a Linear Template in the template library. This is because I want the Item Type to be automatically applied when the Linear Template is used, rather than using the Linear Template and then manually adding the Item Type afterwards. Is this possible?
  • Hi Mary,
    We do this using ORDs Asset Manager to bulk apply them to a complete model. We've also been using various VBAs to automate the manual Item Type attach processes.
    Mark
    OpenRoads Designer 2022 R3 (10.12)  |  Microstation 2023  |  ProjectWise CE 3.4
  • Use Attach Item Types to do it per selection set or as Mark has suggested use Asset Manager to filter you data to attach Item Types automatically
    Chris
    AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
    Associate Director – Digital
    OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
    Civil 3D 2023 | Dynamo | Navisworks Manage
    PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
    Speckle | BIMVision | Revizto | Solibri
