Hi, I attached my reality mesh to my design, when I checked the Top view the XY coordinates (northing,easting) line up right on the money, when I rotated to check the side view I noticed the reality mesh is floating way above the Bing Map, I've already checked my control points in the mesh and they are correct on the NAVDD 88 datum, my question is should the realtiy mesh line up vertically to the BING map or is there no vertical datum vectorized in the BING map?
Is the BING map drapped on a DTM? If not it will just be at 0 Z value.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Hi Brian,
As far as im aware, the Bing Maps imagery is located at zero elevation. You can add Bing Map data to your Reality Mesh so it gets "stiched in" or use ConceptStation to get it to create one for you.
Mark
No it’s not draped , just an attribute view of map background, if its at 0.0 elevation than that makes sense,
