Can I have different sheet sizes and or scales in the same dgnlib, or does each sheet size and scale need to be in its own sheet definition.dgnlib?
I am looking for information as to whether different sheet sizes like ANSI B, ANSI D and ARCH D can exist within the same sheet definition.dgnlib, or if all sheet sizes and scales need their own dgnlib.
Troy D
Parents Reply
  • There may be some confusion here - I think Troy is asking about sheets and scales when creating plans, profiles, or cross sections when using Civil Name Boundary - whereas Brian is using a seed file to create a new (standard MicroStation) sheet model.
    Troy - assuming that you are talking civil named boundaries, it is possible to have different sheet sizes in the same dgnlib, but it is not the way I would recommend. The scales can be changed when creating the drawing i.e. you do not need separate dgnlibs for every scale.
