Geopak Earthwork Finds Old Cross Sections
I am running a topsoil stripping input file via the "Process Cross Sections" function in Power Geopak SS4 and it seems to find old cross section line work/line work that is not there. See the image below. This dgn file has multiple cross section models in it (3 to be exact). There are no references attached in the model I am running this input file in.
I remember running into this issue many years ago and the solution was to recut new cross sections. Is there an easier way than starting all over? is this a .rsc file issue? What am I missing?
Thank you in advance.
