I have my user preferences set to the correct working directory for my project, I open corridor modeling select my template library and set the correct dtm path and import, go to ddb and import our companys ddb file, Go to dtm and select the tin and import that, Then for some reason when i get to geometry it starts to slow down and freeze and when i try selcting the chain, drafting standard and profile it goes slow, i can import it and it says it imported sucessfully. When I move onto plan graphics it also is slow and when I chose selection set and highlight existing ground only (that has no gaps in it) and select import i get a "error storing alignment, status=677" which I dont understand then there is nothing in my ALG viewer. Also when I go to roadway designer within corridor modeler and select the rdp I created with the geometry imported, It will not load my horizontal alignment. If i click the drop down box it is blank. Images of the errors are below.
I found that the following fixed the issue - currupt alg file, delete alg file out of rddbs folder, re load project manager, path everything right, then re do corridor modeler and re import everything, ALSO MAKE SURE PROJECT MANAGER IS LOADED BEFORE YOU OPEN CORRIDOR MODELER
Answer Verified By: Brandi Duzz
