Is there a way in ORD to place a label using a key-in? I have created a cell and dimension style with the same name as the cell and it works fine using the place label button but I can't get it to work with the 'placelabel cellname' key-in. I would ultimately like to create a button that will set the element template / level / set the cell and dimension style and allow me to click on the element to label and place the label. The label that I have setup is to label the geometry point name.
Found the following key-in that allows you to run commands - runxcommand
Coupled with the following command found back stage for the Place Label button - Bentley.CifNET.DocCenter.PlaceLabelTool
The following combination allows me to do what I want -
runxcommand Bentley.CifNET.DocCenter.PlaceLabelTool
Answer Verified By: Corey Baird
Hi Corey, I think that you can also get access to the same command with the key-in doccenter place label.
FYI, there is also an interesting enhancement request in the backlog:
Thank you Marc. This is great information.
