PDF I am trying to migrate a firm from V8i to OpenSite Connect 10. Documentation says I should be able to use existing .xin or .smd files for importing points. I have found an example of where these are set in OpenRoads. Does anyone know the correct location to designate a .xin or .smd in OpenSite?
You just found a red herring. The help is out of date. There are tools to help migrate settings on a Wiki page.
Fred:
Chuck is indeed correct. OpenSite Connect does not use an XIN file (or a SMD). That information is now included within various *.dgnlib's.
Here is the learning path for these Connect editions of software (the learning path is for OpenRoads Designer, but most of the concepts are the same).
https://learn.bentley.com/app/Public/ViewLearningPathWithMasterCourseExpanded?lpId=111346&mcId=111346&CourseId=119789&moduleId=119799
Mark
This is a defect of the help: Defect 1024430:[Documentation] Online Help for Survey Still Refers to Linked Settings from Legacy Software and Other Deficiencies
The migration utilities are available here: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/36224/feature-migration-into-openroads-designer-connect-edition
