Hi All
I’ve recently started looking at Aquaplaning in OpenRoads Designer (V. 10.07.03.18 – 2019 Release 2 Update 7).
I’m curious to know if the product offers the capability of having a single report providing a breakdown of all flow lines, and summarising the max depth per flow line?
Currently the only option I see is opening a report per flowline, which would be based on a visual inspection. The below/attached image refers.
Hi Damien,
You can report all Flowlines (or selected set) by choosing all the flowlines (by Level for example) and then running the keyin: terrainmodel flowlines report. Im not sure why this command isnt in the Ribbon already?
Attached are some reports from the ANZ Workspace that filter and colour by Flow Depths - you should be able to change it do what you want if you know a little bit of XSLT.
Aquaplaning-Austroads.zip
Mark
