Self teaching ORD Connect-2020 Release 1 update 8 (coming from MSV8 SS4 & GEOPAK CE Suite)
I have an alignment and have three profile views: Centerline and right and left side curblines. Maybe I'm already doing this wrong, but I'm drawing my existing/proposed utilities in these profile views. The centerline profile worked great, I used Civil Accudraw to place everything at correct stations etc.
When I moved to the curbline profiles to start drawing, I am noticing a discrepancy in the stationing. All the profile attributes, the profile reports, the labeling within the profile window all make sense, but Civil Accudraw is off by exactly 71' when I try to draw something. I've attached a pictures of both the curb profile and CL profile.The only differences between the CL versus the curb profiles is that I projected another profile for curbs for sidewalk elevations and then I drew the proposed curb profile and copied it to the other profile.
I realize that this is my doing....but where would it have happened? and How?
Thanks in advance.
It looks like the Profile you have open is for Line 6. Is this correct? I think something is not right here. I do not see Line 6 listed anywhere in the Explorer > OpenRoads Model, and it should be listed there. I also cannot see the element in the view window until I hover over it with my mouse. If you delete Line 6, then recreate it, at what point does it start this behavior? It looks like me that the stationing is correct from 0+50 to about 0+80, then it jumps during the intersection portion of the line as you describe for the accudraw.
Okay - I see what happened now. I was following a LEARN video, created my edge of pavement and back of curb lines based on offsets from the alignment. Then created my radii at each intersection using the Arcs>Arc Between Elements>Simple Arc tool and accepted the Trim/Extend Both option at the end. I remember watching the video and thinking this was a much better way to do it, because the line was still there and there's not a bunch of extraneous clicking like the Standard MS Tool. But now I see that the distance between the "trimmed" section of line between the radii spring points is exactly 71'. Which explains why as I go down the alignment further, the stationing gets even further off. Even time I go past an intersection the stationing is off by whatever the trimmed out portion of the line is. But the profile doesn't act strange, get truncated or have a missing section, just the stationing makes a jump. Wow....I understand why, but kinda don't. This is obviously NOT how I am supposed to be creating the geometry and cutting profiles.
Ok, that makes much more sense now. I would still expect that OpenRoads Designer should be able to follow the stationing with the CivilAccudraw tool. I'll file a defect for development to review: Defect 1081775:Civil Accudraw Profile Stationing is incorrect when alignment contains intervals
So does that mean I'm doing things correctly thus far? I feel like I could have done it differently to avoid this.....
There are many ways you could do it. Nothing looks incorrect to me. It looks like you are just running into a defect of the software, and you are not doing anything wrong on your part.
Answer Verified By: Steves
Thanks very much for your assistance
