In the generate slope surface dialog box, there's a catch point check box. However you can only select either cut or fill. Is there any way that both cut and fill will display in different colors?
I don't see a way to do this. Whether the catch point is in cut or fill it will only display in the style chosen at the time the command is run.
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
The alternative is to use a linear template consisting of a single cut and fill solution.
I agree w/ Chuck. Linear Templates are more flexible, more powerful, and move forward seamlessly to the latest versions.
Jeff Martin, PE, Civil Consultant, Bentley Systems
