Hi, I am trying to report proposed and existing elevations along alignment at specified interval including level delta similar to annotation on profile.
I have tried the Station Offset Report on alignment with active existing terrain active. ProfileExistingProposedElevation.XSL looks like the best report for this task but the existing elevations and the cut fill depths are missing.
Is there anything I am missing? Is there any other way to compile such report e.g. modifying a stylesheet or perhaps using different reporting tool?
I have also tried Terrain > Analysis > Points > Analyze Elevation (in 3D model) but I can't specify the chainage interval and it doesn't report the chainage.
Mariusz
Mariusz - the closest I can get now is to use 'Equal Space Points' along the alignment, with levels from the alignment, and then use the 'Analyse Elevation' report - it does not have the chainage, but it has proposed and existing levels, and delta Z.
I select all the points prior to doing the report (for some reason on this model, they appears a long way from the actual model - bug?) Do a Fit View to get them.
Hi Mariusz,
This works fine for us. The key is to use an offset greater than 0 like 0.0001 if the offset element is at a zero offset to the Alignment. This is a bug that we have noticed for a while, but not sure if it's been reported.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Hi Mark, thanks for the tip.
We have tried the greater then zero offset but it didn't make difference when using the Station Offset Report. However, what worked is your setting on Station Base Report with StationBaseOffset-ANZ.xsl. This format doesn't give the level delta but this can be added in Excel.
We have also noticed StationBaseXfall-to-SuperEI_CSV-[x]HS.xsl format in the ANZ section. Do you use these to create superelevation based on existing crossfalls when projecting template points to existing terrain? Perhaps this could also be used to annotate super on profile in such cases?
OpenRoads Designer 2022 R1
Thanks Mark, I will have a look - this looks like a possible workaround to a bug which needs Bentley's team attention.
Also, it looks like Mark Shamoun has better solution as it provides chainages - see below.
That's right - this is something we put together for that exact reason. It is a workaround for a function we really need - the ability to annotate crossfall between 2 linear elements on Profile Drawings,, just like we did in older software like MX.
