Hi, I am trying to report proposed and existing elevations along alignment at specified interval including level delta similar to annotation on profile.
I have tried the Station Offset Report on alignment with active existing terrain active. ProfileExistingProposedElevation.XSL looks like the best report for this task but the existing elevations and the cut fill depths are missing.
Is there anything I am missing? Is there any other way to compile such report e.g. modifying a stylesheet or perhaps using different reporting tool?
I have also tried Terrain > Analysis > Points > Analyze Elevation (in 3D model) but I can't specify the chainage interval and it doesn't report the chainage.
Mariusz
The reports were added to "correct" some issues with the delivered reports and things added like skipping reporting of gaps in linear elements so we dont see incorrect results.
I recommend you learn some XSL as the reports can be easily edited to give you what you want in the first instance with a minor change, instead of having to post-process them in Excel.
Mark
That's great, thanks Mark.
Have you been given an Enhancement Request ID for this badly needed functionality?
Also, correct me if I am wrong, but I understand the superelevation data in CSV format to work require empty rows between each row of data. Do you use some macro to format the output from the StationBaseXfall-to-SuperEI_CSV-[x]HS.xsl to insert these empty rows?
We will definitely explore the XML / XSL as this opens new capabilities. It would be still great if the standard delivered XSL reports were updated from old InRoads to work in ORD.
OpenRoads Designer 2022 R1
It looks like a small change occurred in the report structure and must be changed in the XSL.
Where @existingGroundElevation is found it should be replaced with centerLinePoint/@existingElevation
So the path is not anymore centerLinePoint/point but centerLinePoint and the value has changed from @existingGroundElevation to @existingElevation
Report with a zero offset does work well once correction done in the XSLs.
Here are the XSLs (from Default/Reports/StationOffset folder) where I fixed the issue:
StationOffsetAlongSingleAlignmentExistGround.xsl
ProfileExistingProposedElevation.xsl
ProfileExistingProposedElevationExtended.xsl
ProfileStationOffsetElevationASCII.xsl
Excellent, jpln. I found the issue with the "ProfileExistingProposedElevation.xsl" a few months ago, but did not follow up to other xsl's where such could have taken place. A nice bit of work here!
Best Regards,
The nice notepad++ capability search/replace in all opened files.
