I was wondering if it possible to import horizontal geometry (complex chain) from drawing in Openroads, as it was possible in Inroads.
In the Geometry tab, General Tools, use the Design Elements > Create Civil Ruled Feature.
Hi Mark, thanks for reply, can you give me a tip where can I find description of this tool? Because when I try Create Civil Ruled Feature and try to mark element from drawing(element which is not created by geometry tools) it inform me that - element not valid for tool. All what I need as before is easily import lines, arcs, etc from diferent drawings which I get to horizontal geometry
What version of ORD are you running? Is the element in the drawing, or is it referenced from another file?
I have simply used either Place LIne, Place Smartline, Place Arc, created a Complex Chain - all become horizontal geometry with this tool. There is nothing special about my element - simple MicroStation elements.See the note below from the Help file, which you must have read.
Note: The element must be in a 2D design model to be able to convert it to a Civil Rule Feature.
Thanks I will try your tip. I did not try it in 2D design mode. I did not noticed:-(. I tried it from both referenced file and from same file. I am working with ORD2020R1
