Triangulation Between Hydro and Topo Survey Data
I have a multibeam bathymetric survey and LiDAR around a caving stream bank, and the reality for most of it is that the bank probably has formed temporary shallow "caves" for much of it, though some probably did collapse between the two different survey dates.  When triangulating the points, ORD seems to be picking the shortest trianulation path for the XY direction, and ignoring the Z direction, creating these "spikes" instead of a nice smooth terrain.
Is there a way to adjust how the TM triangulates to adjust most of these, and perhaps identify which points need to be removed to account for subsequent micro-failures in the stream bank?
Otherwise I suppose I'll have to manually clip down the earlier data set POD file before extracting both to create the Terrain Model.
Parents Reply Children
