Hello everyone,
please suggest how I can save my DGN in lower version in openroads designer.
DGN is prepared in 2020 release 1 and its not opening in 2019 release 2 so please suggest how I can covert it to it's lower version so it will also open in lower version of openroads designer.
Vishnu
Mark, I want to be begin by thanking you for the support you provide all of us on the forums, I am grateful for it. I understand that your are not involved in development, but you do work for Bentley. As MaryB and caddcop have eluded to, this is a significant issue, that does need to be addressed. So, as you suggest, I will raise this issue as a service request and will encourage any one else to do so if that is the needed path to get this addressed. Second, I pose this question: Who is it at Bentley that I should contact to find answers to this question?
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022 / 2024
I see that this thread is a bit stale, but I'm hoping that is due to a newly discovered work around or fix. I currently have a Topo file in version 10.09 but the client only works in 10.08. Is there anything that can be done to make this work?
If not, how does Bentley envision being able to work with this? As new updates come around to either fix broken tools or add missing tools, I will need to make a fresh installation to have 10.08 and 10.09 on my machine? Then selecting my project from the list, I will need to know which projects were created in which versions? Will each version require it's own workspace? Am I missing something?
Any sage advice is welcome!
Ken
In v10.9, you can save back to v10.8 or v10.7. File > Downgrade Civil Model
Thank goodness! Any caveats?
You won't be able to open it up to make sure everything came across correctly. Since we can only have one version of ORD installed at any time, there is no way to backcheck any downgraded files for design integrity.
This is just going to become a bigger problem as different clients settle on different versions.
MaryB
